Beginner question: change layer colors in QField
Hi, I uploaded my first project to QField: a topographical raster, an orthophoto raster, three line vector layers (race courses), polygon layer for “forbidden areas”. What I can’t do is change the colorfor each of the three tracks and the polygon layer. In QGis desktop they are different colors, but in QField everything appears all some color blue! Is possible change colors “on the field” directly from the app? Help!
thnk for attention
Mario
Hello @Mario_Crevato , I don’t think there is a way to change the layer colours from QField, maybe editing the .qgs file with a text editor, but good luck with that!
QField should replicate pretty much exactly what you’ve set on QGIS, the scale of things might be a little different but not the colours. Maybe you’ve edited your main project on your computer instead of the copy that QFieldSync makes to transfer? This second one is usually located on your user folder > QField > QFieldCloud (if you are using it) or Export if working with wire transfer.
Ok resolved! I use Project Packager instead QFieldSync=>Package for QField !:zany_face:
Thnk :waving_hand: :+1:
Mario
