Crash when opening menu with REST raster layer
Hello, I am using the QField app on ios. the map works well, until I include a ArcGIS REST raster service. When a REST raster in included, the map displays and loads well, but crashes when I open the menu. Any suggestions from the community? Thank you.
I have had the same problem with the 4.0. With a snowfall layer from a rest server. It works until I expand the layer legend, then it crashes whenever I try to get to the menu. I have to delete the project on the iPhone and redownload a fixed version from qgis and Qfieldcloud.
@Jerome_Delbridge , @Howieb , would you be able to share a sample project with which I could replicate the crash? If so, please go over the QField repository (GitHub - opengisch/QField: A simplified touch optimized interface for QGIS) and file an issue with the sample project.
For everything else - from celebrating QField to asking project configuration questions - let’s meet here :slight_smile:
Mathieu,
Done. Thanks for looking into this.
Thanks for the report and sample project – fix here: Don't crash when fetching legend image from arcmap map services by nirvn · Pull Request #7091 · opengisch/QField · GitHub
