I’ve installed qfield updated to the latest version in my Win11 tablet.
The Qfield project is correctly working in 2 different PCs, but when I try to take a picture with the tablet the system crashes. No error is found.
Any clues?
Qfield version is 3.7
Qgis Version 3.4
Thanks a lot
Hi @ande90r - Depending on whether you are using the desktop version (I do not think you do) but then QField will automatically close if you are trying to take a photo. Are you able to add photos from other directories?
Have you checked the logs?
Hi there,
how can I check if it is a desktop version? I installed it from the App Store, actually.
Yes, I can add pictures from other directories.
Unfortunately, after the crashes the log is empty at the next restart.
Hi @ande90r - if you install QField through the Microsoft App Store then you have the Windows version - you cannot use your camera. If you download QField from Google Play Store or directly from GitHub then you can try and download the .apk extension
actually I solved the problem downgrading the Qfield version to 3.3.11!
Thank you for your help!
