QField crashes when taking a picture
We are working with ok but not super tablets (Galaxy Tab A 10.1 and 10.5).
We’ve had this issue come and go, but we never could pinpoint the problem.
Essentially, most of the time, when we try to take a picture, the app will crash.
Sometimes, it happens when we tap on the camera icon, other times when the picture is taken and tap on the OK button.
The same project works flawlessly on my newer phone, so I suspect this has something to do with the switch between the camera and QField.
I tried to use the minimalistic QField cam, without success.
In the past, I used Open camera app to replace the base Android cam app, but since later updates, we no longer can choose the default camera app, so I can’t use this workaround anymore…
Imported from GitHub discussion by @OBVYamaska on 2022-05-24T14:39:31Z
If this can help in any way:
I obtained “slightly” better results when adding pictures directly to the first form from the map.
In other words, I cannot use the suggested way (creating a dedicated Pictures form and link it with a Relation), nor can I take pictures in “second level” form, linked via a Relation.
But with the direct picture field added to a simple form, I “sometimes” am able to take a picture. This is highly unstable, though.
Imported from GitHub comment by @OBVYamaska on 2022-06-13T23:55:05Z
I had the very same issue - QField being unstable on Galaxy tablet when pictures were involved.
Because I work for a company we were able to change Samsungs for Unitech TB85 tablets with Android 8 and the issue is gone, the QField works almost flawlessly…
I know the solution above is not the best due to costs but for some reason the QField performance on Galaxy series is disappointing
Imported from GitHub comment by @maciejsznajder on 2022-07-20T07:19:21Z
This is reported as bug here: QField ver. 1.8.2 crashes after photo collecting attempt (Android, Samsung Galaxy Tablet) · Issue #1671 · opengisch/QField · GitHub
Imported from GitHub comment by @meyerlor on 2023-04-12T10:37:11Z
Hello, I’m having the same issue but with Win11 tablet, any clues? Qfield is updated to latest version.
Thanks a lot
hello,
i have the same problem with QField Windows (3.7.6).
Cordialy
geguil
Hi :slight_smile: Thanks for your post. You cannot take photos with the Windows version - You can only attach photos.
OK
Merci pour l’info
I think this was possible with older versions
