Data uploading problems
Good morning.
I am using QField 2.6.0 with QGIS 3.22.12 (QFieldsync 4.2.0 plugin).
I have a QGIS project in which I have a point layer containing some photo fields (in these fields I have set the attachment form fields to use “relative path”).
I have the following problems (this happens on several smartphones):
  1. After collecting the data in the field, if I click the “push changes” button and then synchronise the project with QGIS on the computer, the only data that is synchronised are the photos, which are saved correctly, but the points are not there. If I open the project folder with QField and email the file “data.gpgk”, this file, opened with QGIS contains the missing points.
  2. If, using the QField app, I do not click on “push changes” but on “Synchronize”, when I synchronise the project with QGIS on the computer, both the photos and the points are synchronised, but there is another problem: all the points, collected from different smartphones, are synchronised, but only the photos taken by the last operator who clicked on “Synchronize” are synchronised on the computer
The point layer with photos is a Geopackage
What am I doing wrong? Has this already happened to someone?
Thank you!
Imported from GitHub discussion by @giuenrico93 on 2023-01-19T15:39:33Z
