Hi there,
I created in a QfieldCloud project a point layer that contains IDs and photos (paths) in QGIS. When I use this in Qfield I’m able to see the path or URL and if I edit the layer I can add a point and also take a picture. I understand the picture get usually store in a relative path and if I sync the project I can see that Qfield idenfy the changes and apparently push the data to the cloud.
Now, when I sync the project in QGIS to check the new points, the changes are just not there. I downloaded and imported the data from the webview and just the changes without photos got digitized.
I tried refreshing and opening the project from the cloud in QGIS and neither the changes in the point layer with photos and not photos got updated.
Please let me know if I wasn’t clear enough.
Kindly,
Giovanny
Imported from GitHub discussion by @gi921120 on 2022-03-15T07:09:49Z
gi921120 can you share your username/project name, or the project data itself, so I can see what happened in the logs?
Imported from GitHub comment by @suricactus on 2022-03-15T07:41:35Z
Sure thing.
User: gi921120
Project name: Sydney_Gateway_Test_1 / Data_field_test_1
Thank you
Imported from GitHub comment by @gi921120 on 2022-03-15T08:20:31Z
Hey gi921120 . Thanks for the details. If you check the jobs tab of your project in the web UI, you should see a job of type “packaging” with the following table:
Layer Name Layer Id Is Valid Status Error Summary Provider Summary
Basemap ...f1f974 False invalid_dataprovider Cannot open GDAL dataset /John Holland Group/Sydney Gateway Survey - GIS/Qfield/Test 21 Richard/basemap.gpkg: Cannot open GDAL dataset /John Holland Group/Sydney Gateway Survey - GIS/Qfield/Test 21 Richard/basemap.gpkg:
Google Hybrid ...32ca6f True no_error
IFC Design Road Alignment _220120_L ...941dfc False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/Qfield/Test 21 Richard/data.gpkg" missing.
PUP_Geotagged Photos_220301 ...ffcce2 True no_error
Stage 3 Phase 1 3A ...2306e6 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210726_Partial_Update/Stg 3 Qantas Drive Stage 3 Phase 1 3A.dxf_SHP(byLay)P.shp" missing.
Stage 3 Phase 1 3A ...bf8913 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210726_Partial_Update/Stg 3 Qantas Drive Stage 3 Phase 1 3A.dxf_SHP(byLay)F.shp" missing.
Stage 3 Phase 1 3A_3D ...ae9632 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 1 3A_3D.dxf_SHP(byLay)F.shp" missing.
Stage 3 Phase 1 3A_3D ...5089bf False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 1 3A_3D.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 1 3A_3D ...76d152 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 1 3A_3D.dxf_SHP(byLay)P.shp" missing.
Stage 3 Phase 1 3A ...944b0e False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210726_Partial_Update/Stg 3 Qantas Drive Stage 3 Phase 1 3A.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 1 3C ...497a4c False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210726_Partial_Update/Stg 3 SRAD Stage 3 Phase 1 3C.dxf_SHP(byLay)F.shp" missing.
Stage 3 Phase 1 3C ...6f3cb7 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210726_Partial_Update/Stg 3 SRAD Stage 3 Phase 1 3C.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 2 3A_3D ...281a75 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 2 3A_3D.dxf_SHP(byLay)F.shp" missing.
Stage 3 Phase 2 3A_3D ...c5d6b3 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 2 3A_3D.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 2 3A_3D ...848230 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 2 3A_3D.dxf_SHP(byLay)P.shp" missing.
Stage 3 Phase 2 3C ...08d498 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 2 3C.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 3 3A_3D ...57d432 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 3 3A_3D.dxf_SHP(byLay)L.shp" missing.
Stage 3 Phase 3 3A_3D ...ea648f False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 3 3A_3D.dxf_SHP(byLay)F.shp" missing.
Stage 3 Phase 3 3A_3D ...93edfd False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 3 3A_3D.dxf_SHP(byLay)P.shp" missing.
Stage 3 Phase 3 3C ...ff7c88 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_210624/Stage 3 Phase 3 3C.dxf_SHP(byLay)L.shp" missing.
Traffic_Management_ForeCast ...aed060 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/Mergin/Test Traffic/Traffic_Management_ForeCast.gpkg" missing.
X-0246-03-TS-3300-PLAN-BARRIER_L ...1d1655 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_211129_Stage 3/X-0246-03-TS-3300-PLAN-BARRIER_L.shp" missing.
X-0246-03-TS-3300-PLAN_F ...38f15f False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_211129_Stage 3/X-0246-03-TS-3300-PLAN_F.shp" missing.
X-0246-03-TS-3300-PLAN_L ...39a1b8 False invalid_dataprovider File "/John Holland Group/Sydney Gateway Survey - GIS/GIS Data Master/Shapefiles/Traffic/TS_211129_Stage 3/X-0246-03-TS-3300-PLAN_L.shp" missing.
The table highlights problems with your project, namely you are refering to files that are outside the directory that holds the test_cloud.qgs QGIS project file, namely three levels up.
Can you clarify how you uploaded your project to the cloud? How did you create your QFieldCloud project, from web or QFieldSync? If the latter, which of the two radio buttons you have chosen?
Imported from GitHub comment by @suricactus on 2022-03-15T13:54:13Z
Hi Ivan,
I created the project with QFieldSync. I found my mistake. I was not paying attention to the two radio buttons.
Kind regards,
Giovanny
Imported from GitHub comment by @gi921120 on 2022-03-16T21:07:32Z
