How can I connect QField to my Azure Postgresql database so that QField can update information collected into my database. Please help
hello and welcome @jameshosiwa . Have you checked the documentation? For example, this article on Working with PostgreSQL might be of use.
Good Day2, yeah, I read through. However, if I try to add qfieldcloud (basic) configuration authentication, I’m getting these errors, but my credentials are accurate, if I deselect it, my connection runs successfully. What’s the matter?
can you share the log message output that the “Connection failed - consult message log for details” warning talks about?
you can find it by clicking on the dialogue icon on the most bottom right corner (“1” on the image below). Check all the tabs (“3” rectangle) from the panel (“2”) that pops up for signs of messages related with this issue, since it’s not always obvious on which one it might go:
