I have a Qfield project with a one to many table relationship. One layer with point geometry (sampling plot) and one without geometry (trees). I see that this is possible: Problems inserting new data into a one-to-many value relationship in Qfield 2022. · opengisch/QField · Discussion #2993 · GitHub
However, I don’t know how I have to configure the QGIS project in order to be able to insert new data to the trees table in QField. In the QGIS project, I joined my trees table to the sampling plot layer, but this doesn’t work.
Imported from GitHub discussion by @Barbara-Schneider on 2025-01-15T11:57:14Z
Hi Barbara-Schneider,
For working with this workflow described, you need to configure a relation of layers (in your case, the point and the trees table). In the project properties, for the field relation, it is highly recommended to use a string field with UUID. You have two options for creating UUID values:
- You can use the “UUID Generator” widget, which will automatically generate unique UUID values for each entry.
- Alternatively, you can use the “Text Edit” widget and manually generate UUID values using the
uuid() expression.
For more reference on how to configure this, check the following documentation:
Imported from GitHub comment by @SeqLaz on 2025-01-15T18:01:25Z
Hi SeqLaz,
thank you very much, this works!
Barbara
Imported from GitHub comment by @Barbara-Schneider on 2025-01-16T09:58:06Z
