Legend symboles very small
In my project i have point symbology that appear like that on map
But in the legend it is very small
With a different theme apply, symbology in the legend is different but stay very small in the legend.
I now the problem come from my symbology…
But, do you how i can do to make it bigger in the legend, with my first theme the symbology is rules-based with 4 symboles (1 principal symbole with 3 symboles (under-symboles) in the principal symbole ) and in the second theme there are symboles ( a principal symbole with 2 under-symboles).
Is there an option in Qgis to show a symbole prior than others?
From what I can see in demo project ‘bee farming’, the size of symbols in the legend must fit in a small square so that space between text lines stays equal. As a matter of fact, big symbols appear small… By the way, I agree that symbols should appear a bit bigger.
About your last question, I’m not sure to understand what you want to do but I’m quite sure it’s possible. Could you share a small project or make screen captures ?
FYI, this is a known limitation (partly QField, partly QGIS) at the moment. And for e.g., with the sample bees project, the drop shadow style makes things even smaller as there’s a bunch of barely visible pixels that end up reducing the size.
For my last question, i would like to priorize the parent symbole (this is the most important for user comprehension), to show it more big in the legend.
Others child symboles are less informative
Hi @woupss , following @Mathieu_Pellerin answer, it seems there is no good direct control over the icon sizes on the legend section.
Maybe you can add some “fake” pixels around the icon on the symbology side to make the engine render the icons smaller on the menu? Something like what he comments about the drop shadow, or something like a bigger circle with opacity set to 1%, a buffer, etc… Of course there doesn’t seem to be much wiggle room as the icons are pretty small to begin with.
