Localized Data Paths no longer in Data Sources in QGIS 3.44 - How to share datasets between projects now?
Hi all
I was wondering if the user guide and documentation for localized data paths should be updated?
I tried it in QGIS 3.44 and see that the QGIS Data Sources looks completely different from what is in the documentation.
  • Where does the user find the “Localized Data Paths” option now to add for rasters shared between projects?
This is how it looks for me:
Here how it should look like according to documentation:
Here is the link to the current documentation:
Thanks for the help and maybe docs update if needed.
Seems like you are looking under project properties. You need to look under settings-options.
I just went through this myself.
Howie
Thanks this worked :slight_smile: Indeed that slight difference got unnoticed :slight_smile:
