Hi there,
two of our collegues reported this morning that their project is empty after synchronising. Layers are empty and not selectable. Three other people had turned off automatic update before and have no problems. Thus, it seems very likely that the update hast caused the data loss.
Since field work goes on tomorrow, I would appreciate very much a quick solution.
Thanks, Peter
Now it works fine, again. No clue why.
if you are using the official qfieldcloud instance, there are reports of issues as of last week and a couple of days ago it was reported that there would be some downtime due to some maintenance and server update: Maintenance Announcement | QField Ecosystem Status , so maybe you just had some bad luck with the server. Also, there seems to be some sporadic “service degradations” on the monitor, but I’m not sure what is considered a “dagradation” or a “failure”: https://qfield.checkly-dashboards.com/
