QFieldCloud
Hi Everybody,
I have been setting up a QFieldCloud Project - I first saved the project under a specific name, added all the files and styled them in the way I want them to appear on the cloud and on QField on my devices. However when I remove any of the shp file layers in the QGIS app on my computer, synchronize the QFieldCloud Project and try to add these or other shp to the project on my computer and synchronize the project again, I always get a packaging error. Basically it appears that once I remove a layer I cannot add it again (or not add any files later on, which cannot be true) because it will not package it properly and not display in QField on my android device. The message I get on QField on my tablet is “QFieldCloud had trouble packaging your project” and further below it says for each layer that did not load again after I had removed and reloaded it (or added anew after creating the cloud project) on my computer and synchronized the project to the cloud “Packed layer ‘USP_001_Survey Grid’ is not valid. Error code invalid_dataprovider, error message”/tmp/tmp294gmyu3/The Umma Survey Project/Field Work Data/ April 2022 Season/USP_001/USP_001 […] missing." The only workaround is that I delete the current QFieldCloud Project add all the layers I want, package it and then reload the new QFieldCloud Project on my tablet. But it appears as if I cannot remove and reload files from the project itself nor add new files to it and synchronize the project.
Any advice? Would appreciate any help.
Thank you
Imported from GitHub discussion by @enheduanna on 2022-03-29T04:51:39Z
