QFieldCloud's ip addresses for PostGIS access
We have a QFieldCloud project which uses a PostGIS db. We had to open the db to the world as explained in the doc, it’s working fine. But I would prefer to be able to limit access to the db to QFieldCloud servers only. Do you have an ip list or range we could use?
Best,
Nicolas
Imported from GitHub discussion by @nicdub on 2023-02-03T16:53:29Z
Hey, nicdub . Please find the IP which QFieldCloud runs here: Technical specs - QField Ecosystem Documentation . Note this will most probably change in the future, but you can consider it stable for the next few months.
Imported from GitHub comment by @suricactus on 2023-02-04T10:05:11Z
Hey suricactus, thank you for your prompt response!
Imported from GitHub comment by @nicdub on 2023-02-06T08:22:16Z
