Self hosted Cloud : Failed to upload "data.gpkg": [QT-2] Connexion fermée
We have implemented your QFieldCloud on our server.
Our cloud runs on DEBIAN12 OS with a i5 processor, 16GB RAM and 500Go of disk space.
The configuration has been mounted under DOCKER as specified in the GitHub page and we run the docker-compose.override.test.yml.
I can’t upload a qgs project or any gpkg because the Connexion is closed.
The errors are “Failed to upload “data.gpkg”: [QT-2] Connexion fermée” or “Aborted “communes.gpkg” upload”. We have solved the subscription problem but I don’t know what causes these problems.
Can you help me ?
Thank you
Imported from GitHub discussion by @sigsdis30 on 2023-07-31T07:01:29Z
See self hosted Cloud : Failed to upload "data.gpkg": [QT-2] Connexion fermée · Issue #755 · opengisch/QFieldCloud · GitHub
Imported from GitHub comment by @suricactus on 2023-07-31T08:53:42Z
I put the same one on both forums.
So that if people on this one know something, they can help :slight_smile:
Imported from GitHub comment by @sigsdis30 on 2023-07-31T09:36:48Z
I really need help… I can’t work if that problem is not resolved…
Imported from GitHub comment by @sigsdis30 on 2023-08-02T06:55:03Z
Feel free to ask for dedicated support at salesopengis.ch .
Imported from GitHub comment by @suricactus on 2023-08-03T11:18:11Z
Hi sigsdis30 , did you solve the problem?
I’ve deployed the qfieldcloud on my server; should I recompile the qfieldcloud sync plugin to change the server ip ?
Imported from GitHub comment by @nesar77 on 2023-09-04T13:00:42Z
Hi nesar77,
Do you have an email address with which we can talk about it or maybe help each other ?
Imported from GitHub comment by @sigsdis30 on 2023-09-05T10:08:20Z
