Turn off map canvas rotation
Seems like a really basic thing, but I would like to be able to turn off the map canvas rotation for v2.7.0. This is a handy feature when trying to navigate following a line or something like that, but it seems to rotate every last time I zoom in or out. I would much rather have a north-up orientation unless I specified otherwise. How do I change the settings to this? Nothing stood out to me in the settings or documentation.
Imported from GitHub discussion by @AK-survey on 2023-03-14T21:36:20Z
AK-survey , what about increasing the threshold for rotation to occur instead of adding a cumbersome toggle? When you zoom in/out in say Google Maps, do you feel you also hit accidental rotation there or not?
Imported from GitHub comment by @nirvn on 2023-03-15T02:37:07Z
AK-survey , follow up question: do you feel you’re mostly triggering accidental rotation when zooming in or zooming out?
Imported from GitHub comment by @nirvn on 2023-03-15T06:26:18Z
AK-survey , in 10 minutes or so some APKs will be up in this PR (Give the rotation threshold a higher value by nirvn · Pull Request #4045 · opengisch/QField · GitHub) for you to try. The rotation threshold has been increased to try and avoid accidental rotation.
Imported from GitHub comment by @nirvn on 2023-03-15T10:10:46Z
A threshold value would be great, especially being able to customize it from settings. 10 degree increments would seem reasonable, with 0 degrees being no restriction and 90 degrees being no rotation ever. I found no difference with accidental rotation zooming in vs out. I just tried the PR 4045 beta and it worked great. As far as I’m concerned, I would stick with that threshold or make it the default if options are given.
Imported from GitHub comment by @AK-survey on 2023-03-15T22:03:08Z
AK-survey , good. Our initial threshold was tentative, and we weren’t quite sure it was high enough. I think you’ve answered our question here :slight_smile:
Imported from GitHub comment by @nirvn on 2023-03-16T02:00:57Z
I’ve often wondered how to block the orientation of the map. Because too often, it turns accidentally. Pressing north only reorients the map. The best thing would be to be able to deactivate this function.
Imported from GitHub comment by @aghiraldi on 2023-07-13T09:00:43Z
