I’ve been shifting more and more of my field mapping from Avenza to qField, once I got qField working and syncing properly there’s really no comparison between the two. At the moment, I am primarily using the basic cable/file transfer sync option, rather than qFieldCloud.
One thing I am still running into, however, is that if I want a truly offline project, I have to put everything I want on my device, including aerial imagery. We have some projects that cover a pretty wide area, so although I can clip a portion of an NAIP aerial and load that onto the device as part of the project, that often takes up several gigabytes of storage space, and if you’re working on multiple projects at once, that eats up memory pretty quickly on a mobile device.
The question I have is this - Is there a way to cache imagery data from a WMTS for later use? As long as I have cell service, using a WMTS layer for my imagery works great, and I’ve found that, as long as I have the same instance of the app and project open, qField actually does cache some WMTS data, i.e I can open the app on a hilltop where I have service, zoom in on my area, then head down the hill, drop out of service, and still be able to see the tiles that I loaded when I had service. Unfortunately, the moment I close the app, or even back out to the project screen and re-enter the project, I see the following message
Some of the folks at my company are still using PC-GPS, which uses an app provided aerial basemap, and as long as you’ve zoomed in and looked at the imagery for the area you expect to be using offline, when you are offline that imagery will still be cached on the device, albiet at the extent and resolution that you recently looked at it.
Is there any way in the current interation of qField to do something similar, i.e. to cache data for later use from a WMTS?
If anyone has any thoughts or ideas I’d be delighted to hear them. Thanks!
Imported from GitHub discussion by @seades0630 on 2024-04-01T19:52:28Z
