Hi
I am functional in QGIS but definitely not wizard. I am setting up an archaeological field project and now want to test the GFieldCloud. I understand that I set up the project on QGIS Desktop as I would if I would use the traditional sync feature. I do see the cloud in the QGIS desktop interface but it says I am logged out and when I click on it - it will not allow me to log in. Do I have to create the project in the cloud first or should I be able to create the project in QGIS desktop and the push it to the cloud from where I can push it onto a device of mine and then started editing in the field and push it back to the cloud once I am done?
Thank you
Stephanie #
Imported from GitHub discussion by @enheduanna on 2022-03-22T02:07:56Z
hi enheduanna .
Can you give a little bit more details about your QFieldSync plugin version, QGIS version, Qt version and your operating system?
What exactly happens? You don’t see the login form? Or it shows “login failed”?
Please give as much details.
Best,
Ivan
Imported from GitHub comment by @suricactus on 2022-03-22T07:43:07Z
I believe your issue might be similar to this one here. QFieldCloud: missing login dialog · opengisch/QField · Discussion #2732 · GitHub
Imported from GitHub comment by @suricactus on 2022-04-25T21:43:29Z
Dear Ivan
Thank you very much but in my case the issue was that I had to download the
new version of QGIS and also the black developer app and then it worked. I
signed in online and it worked also on QGIS and on the mobile app. I am
using it now on several tablets and it works just fine.
Than you very much for reaching out.
Best wishes
Stephanie (aka enheduanna)
On Mon, Apr 25, 2022 at 5:43 PM Ivan Ivanov @.***>
wrote:
I believe your issue might be similar to this one here. #2732
https://github.com/opengisch/QField/discussions/2732
https://github.com/opengisch/QField/discussions/2628#discussioncomment-2634195,
or unsubscribe
https://github.com/notifications/unsubscribe-auth/AHTBJ2QIATYPRXCFXCLSHW3VG4GYXANCNFSM5RJOR6DA
You are receiving this because you were mentioned.Message ID:
Imported from GitHub comment by @enheduanna on 2022-04-25T21:55:06Z
Since you are there and you have opened a few issues on the github discussions page, please make sure to answer/update them if you are no longer experiencing the problems.
Imported from GitHub comment by @suricactus on 2022-04-25T22:05:49Z
Noted with thanks - will do in the future.
Sorry for not realizing sooner.
On Mon, Apr 25, 2022 at 6:06 PM Ivan Ivanov @.***>
https://github.com/opengisch/QField/discussions/2628#discussioncomment-2634291,
or unsubscribe
https://github.com/notifications/unsubscribe-auth/AHTBJ2UD5VDCVZ2G2NRQDMDVG4JMPANCNFSM5RJOR6DA
Imported from GitHub comment by @enheduanna on 2022-04-25T22:09:30Z
