Can't login in the qFieldSync plugin
I successfully used qGIS on a pc till yesterday, and synchronized the projects on my android phone using the FieldSync plugin with qFieldCloud.
Now I started on OSGeoLive (lubuntu), and now I’m not able to log-in in the qFieldSync plugin.
Clicking on the blue cloud icon, the window says “Signed out”, and apparently there is no way to sign-in.
It always worked on pc, can’t belive it doesn’t works on linux!! Surelly I’m doing something wrong.
What should I do?
Imported from GitHub discussion by @Martinetta on 2022-12-21T22:13:58Z
Hi Martinetta . It surely does work on linux, the plugin development is on Linux. Are you sure you type your credentials correctly?
Imported from GitHub comment by @suricactus on 2022-12-22T08:52:18Z
Thanks suricactus , even if I’m pretty sure that the pw was correct, I tried to check, but I can’t (I’m not able to) write the credentials again, because all the buttons in the QFieldCloud window are grey. Can’t find another place where to write the credentials.
I don’t remember if it asked me to write my username.
I tried to uninstall the plugin, switch off everything, switch on and reinstall the plugin, but it doesn’t ask me the username again, always asks to the pw and than, clicking on the blue cloud icon, says “signed out”.
Imported from GitHub comment by @Martinetta on 2022-12-28T16:44:48Z
Solved in the most brutal way: uninstalling qGIS, switching the computer off, keeping it off during 1 minute, reopening and reinstalling everything, now the log-in window correctly appeared, and the plugin works perfectly.
Imported from GitHub comment by @Martinetta on 2022-12-28T17:51:12Z
Sometimes a bit of brutality brings peace :slight_smile:
Imported from GitHub comment by @suricactus on 2022-12-29T09:57:28Z
Same on MacOS. Best to avoid this plugin on MacOS until a solution is found. An alternative is Mergimmaps that works seamlessly
Imported from GitHub comment by @roryfogerty on 2023-11-16T03:39:43Z
I am using Ubuntu and QField(sync) since years; it runs smoothly
Imported from GitHub comment by @BoswachterMarc on 2023-11-16T16:49:20Z
Thanks, I know it runs on Linux, I dont have a Linux laptop, I have a Macbook and it doesn’t work on that.
Imported from GitHub comment by @roryfogerty on 2023-11-16T17:10:35Z
roryfogerty sometimes on MacOS the login dialog gets into the background of the main QGIS window.
Imported from GitHub comment by @suricactus on 2023-11-16T23:42:58Z
Hi, thanks for your reply. Found it and all is well. Would be good to
mention something in the documentation..
On Fri, 17 Nov 2023 at 12:43, Ivan Ivanov @.***> wrote:
roryfogerty https://github.com/roryfogerty sometimes on MacOS the
https://github.com/opengisch/QField/discussions/3763#discussioncomment-7593508,
or unsubscribe
https://github.com/notifications/unsubscribe-auth/ABZUX4KM465LPAG42CEQT4TYE2QI3AVCNFSM6AAAAAATGCTNROVHI2DSMVQWIX3LMV43SRDJONRXK43TNFXW4Q3PNVWWK3TUHM3TKOJTGUYDQ
You are receiving this because you were mentioned.Message ID:
M: 021 314933
The information contained in this E-mail is CONFIDENTIAL and may be LEGALLY
PRIVILEGED, intended only for the recipient named above. If you are not
the intended recipient, you are notified that any use, review,
dissemination, distribution or copying of this message is strictly
prohibited. If you have received this message and attachments in error,
please notify the sender and destroy the original message. Please note the
views that are expressed in this E-mail do not necessarily reflect those of
the company.
(Please consider the environment before printing this e-mail)
Imported from GitHub comment by @roryfogerty on 2023-11-17T02:53:24Z
Thanks for the reply! Will consider mentioning it.
Imported from GitHub comment by @suricactus on 2023-11-17T03:06:58Z
To summarise,
QFieldSync is mainly developed on Linux, so for sure, it works on it, possibly something went wrong Martinetta. Good you could solve it by reinstalling.
As suricactus mentioned, sometimes on MacOS the login dialog gets into the background of the main QGIS window (personally had it once in a course). A simple cmd + tab brings the windows to the front.
Edit: the latest version released (4.6.1) should take care of this for good.
Imported from GitHub comment by @mbernasocchi on 2023-11-17T09:56:32Z
roryfogerty I think your Best to avoid this plugin on MacOS is rather strong. QFieldSync is regularly used by numerous MacOS users with success.
Imported from GitHub comment by @mbernasocchi on 2023-11-17T09:59:11Z
By the way, we just released a new version that should take care of this for good.
Happy to hear your feedback
Imported from GitHub comment by @mbernasocchi on 2023-11-18T17:38:21Z
